slavon73
4 Ниже средней
О slavon73
  • День рождения 09/20/1973
    Чистополь
839 просмотров профиля
  1. Спасибо! В таком виде опубликовалось <?xml version="1.0" encoding="utf-8"?> <Message> <VerificationMeasuringInstrumentData> <VerificationMeasuringInstrument> <NumberVerification>111111111</NumberVerification> <DateVerification>2023-04-03</DateVerification> <DateEndVerification>2029-04-02</DateEndVerification> <TypeMeasuringInstrument>счетчик</TypeMeasuringInstrument> <ApprovedEmployee> <Name> <Last>Иванов</Last> <First>Руслан</First> </Name> <SNILS>0000</SNILS> </ApprovedEmployee> <ResultVerification>1</ResultVerification> </VerificationMeasuringInstrument> <VerificationMeasuringInstrument> <NumberVerification>111111112</NumberVerification> <DateVerification>2023-04-03</DateVerification> <DateEndVerification>2029-04-02</DateEndVerification> <TypeMeasuringInstrument>счетчик</TypeMeasuringInstrument> <ApprovedEmployee> <Name> <Last>Иванов</Last> <First>Руслан</First> </Name> <SNILS>0000</SNILS> </ApprovedEmployee> <ResultVerification>1</ResultVerification> </VerificationMeasuringInstrument> </VerificationMeasuringInstrumentData> <SaveMethod>2</SaveMethod> </Message>
  2. Вот такую ошибку пишетDoc2.docx
  3. Все равно не получается передать xml-файл на 2 записи. Не подскажете, где же ошибка? <?xml version="1.0" encoding="utf-8"?> <Message> <VerificationMeasuringInstrumentData> <VerificationMeasuringInstrument> <NumberVerification>111111111</NumberVerification> <DateVerification>2023-04-03</DateVerification> <DateEndVerification>2029-04-02</DateEndVerification> <TypeMeasuringInstrument>счетчик</TypeMeasuringInstrument> <ApprovedEmployee> <Name> <Last>Иванов</Last> <First>Руслан</First> </Name> <SNILS>0000</SNILS> </ApprovedEmployee> <ResultVerification>1</ResultVerification> </VerificationMeasuringInstrument> </VerificationMeasuringInstrumentData> <VerificationMeasuringInstrumentData> <VerificationMeasuringInstrument> <NumberVerification>111111112</NumberVerification> <DateVerification>2023-04-03</DateVerification> <DateEndVerification>2029-04-02</DateEndVerification> <TypeMeasuringInstrument>счетчик</TypeMeasuringInstrument> <ApprovedEmployee> <Name> <Last>Иванов</Last> <First>Руслан</First> </Name> <SNILS>0000</SNILS> </ApprovedEmployee> <ResultVerification>1</ResultVerification> </VerificationMeasuringInstrument> </VerificationMeasuringInstrumentData> <SaveMethod>1</SaveMethod> </Message>
  4. Может есть у кого пример xml-файла на несколько записей?
  5. По одному проходит, а если несколько записей в файл делать - ошибку выдает, а в чем - не пойму
  6. Техподдержка молчит второй день. Хочу обращение в ФСА написать, подскажите, на чье имя лучше?
  7. Коллеги, а сколько страниц у вас в ЛК можно вывести на просмотр? У меня, если выбрать по 100 строк, доступно 10 страниц; если выбрать 50 строк - 20 страниц; т.е. в любом случае в ЛК хранится только 1000 строк? Или только у меня так?
  8. Попробуйте в xml-файле указать И.О. Фамилия, мне помогло, то же самое было
  9. День добрый! Я вчера в техподдержку через ИП вопрос задал насчет пакетной загрузки, в т.ч. про схему файла, вот их ответ: Здравствуйте! Для сохранения истории взаимодействия при последующей переписке по данному запросу просим сохранять тему письма. ________ Инструкций и шаблонов по данному модулю нет, дата появления не обозначена, модуль работает в тестовом режиме. В случае отсутствия ответа обращение будет закрыто по истечении 5-ти рабочих дней автоматически. Спасибо за обращение в техническую поддержку ФГИС.
  10. У нас так же было, но нас эксперт сразу предупредил, чтобы тщательно проверяли загружаемые документы - потом не будет возможности исправить. Сам же эксперт видит загруженные документы, а мы нет. Кстати, в инструкции пользователя "TrueConf" тоже сказано, что "4.6 Заявитель, аккредитованное лицо может только загружать файлы без возможности замены"
  11. Была такая же история на днях, писал в техподдержку, вот их ответ: Здравствуйте! Для сохранения истории взаимодействия при последующей переписке по данному запросу просим сохранять тему письма. ________ Если номер обращения не приходит в течении 24 часов, то необходимо направлять повторно. В случае отсутствия ответа обращение будет закрыто по истечении 5-ти рабочих дней автоматически. Спасибо за обращение в техническую поддержку ФГИС. ____________________________ С уважением, Служба технической поддержки
  12. А в графу "Номер результата" что внесли? Номер записи из Аршина?
  13. У нас номер записи в реестре АЛ формата 0000, тоже не проходит - появляется сообщение "Введите номер аттестата полностью", хотя на прошлой неделе пробовал - получалось отправить данные. Написал в техподдержку, ответили: "У Вас устаревший аттестат аккредитации рекомендуем его сменить через официальное письмо в адрес ФСА."
  14. Добрый день! Коллеги, подскажите, пожалуйста. Подавали заявление на ПК-5, 24 сентября 2021. Вчера вышла на связь ЭО, запросили документы для составления договора. А приказ о назначении ЭО должен же быть? Или позже будет, по вашему опыту как это происходит?
  15. У нас тоже сегодня сменился статус на "В работе", подавали на ПК 23.09.2021
