gazievgayrat 0 Опубликовано 29 Марта 2010 Жалоба Опубликовано 29 Марта 2010 Нужна методика для датчиков давления Цитата
Alex37 28 Опубликовано 29 Марта 2010 Жалоба Опубликовано 29 Марта 2010 Нужна методика для датчиков давления Для каких? :'( Цитата
gazievgayrat 0 Опубликовано 30 Марта 2010 Автор Жалоба Опубликовано 30 Марта 2010 Для каких? :'( DSU: Pressure transducer How energy efficiency is improved Simplest conversion of pressures into proportional standard signal. Areas of application For measuring pressures in liquids, gases and vapours. Non-wearing measurement procedure by means of contact-free inductive signal conversion. Features • Pressure range: 0 to 25 bar • Standard signal 0(2) to 10 V or 0(4) to 20 mA. • Up to 110 °C and up to 40 bar maximum sensor values • 24 V~/=, ± 20% supply voltage P Technical description • Light-alloy housing with transparent cover made of impact-resistant thermoplastic • Ambient temperature: -20 to +70 °C • IP65 Y05043 • Standard housing-mounted plug with cable connector for cables from 6 to 10 mm in diameter • Pressure connection G½"A • Extensive range of accessories Цитата
Orlangur 85 Опубликовано 30 Марта 2010 Жалоба Опубликовано 30 Марта 2010 DSU: Pressure transducer How energy efficiency is improved Simplest conversion of pressures into proportional standard signal. Areas of application For measuring pressures in liquids, gases and vapours. Non-wearing measurement procedure by means of contact-free inductive signal conversion. Features • Pressure range: 0 to 25 bar • Standard signal 0(2) to 10 V or 0(4) to 20 mA. • Up to 110 °C and up to 40 bar maximum sensor values • 24 V~/=, ± 20% supply voltage P Technical description • Light-alloy housing with transparent cover made of impact-resistant thermoplastic • Ambient temperature: -20 to +70 °C • IP65 Y05043 • Standard housing-mounted plug with cable connector for cables from 6 to 10 mm in diameter • Pressure connection G½"A • Extensive range of accessories Круто. А по испански? С наименованием понятно, а тип у них есть? Кто производитель? Они занесены в госреестр? Цитата
gazievgayrat 0 Опубликовано 30 Марта 2010 Автор Жалоба Опубликовано 30 Марта 2010 Загрузил все что есть на этот датчик, описание есть только на англ. Если есть какая-нибудь информация буду очень благодарен en_ds_en525917.pdf Цитата
Orlangur 85 Опубликовано 30 Марта 2010 Жалоба Опубликовано 30 Марта 2010 (изменено) Загрузил все что есть на этот датчик, описание есть только на англ. Если есть какая-нибудь информация буду очень благодарен В гореестре такого не нашёл. Но судя по конструкции должна подойти методика на наш "Сапфир-22" МИ1997-89 ЗЫ: Хотя если их нет в госреестре то и поверять их нельзя. Изменено 30 Марта 2010 пользователем Orlangur Цитата
gazievgayrat 0 Опубликовано 30 Марта 2010 Автор Жалоба Опубликовано 30 Марта 2010 В гореестре такого не нашёл. Но судя по конструкции должна подойти методика на наш "Сапфир-22" МИ1997-89 ЗЫ: Хотя если их нет в госреестре то и поверять их нельзя. Спасибо за подсказку, попробую МИ 1997, скоро оно будет в госреестре Узбекистана Цитата
gazievgayrat 0 Опубликовано 1 Апреля 2010 Автор Жалоба Опубликовано 1 Апреля 2010 Для каких? :'( Датчики давления типа DSU116F001 фирмы Sauter Systems (по моему Швейцарские). Если нужно больше информации, то оно есть в прикрепленном файле (на английском). Спасибо за отклик! преобразователь давления en_ds_en525917.pdf Цитата
manila2211 0 Опубликовано 31 Октября 2010 Жалоба Опубликовано 31 Октября 2010 ооочень нужна Ваша помощь....безумно нужна методика поверки датчиков давления метран 150 ТА МИ 4212-012-2006 (или похожего), нужен сам текст, а ещё было бы неплохо узнать приборы и стенды и условия для проведения испытаний при их сертификации. И если найдёт кто-нибудь текст ТУ 4212-022-51453097-2006, то очень выручит. я не смогла найти( Цитата
vikt0r68 0 Опубликовано 2 Ноября 2010 Жалоба Опубликовано 2 Ноября 2010 Огромная просьба, где можно скачать МИ 1997 -89 в нормальном состоянии. Прошелся по многим электронным библиотекам, но ее или нет, а если и есть то в ужасном состоянии. Может у кого нибудь есть эта методика в электронном виде? Цитата
Artem 56 Опубликовано 2 Ноября 2010 Жалоба Опубликовано 2 Ноября 2010 Огромная просьба, где можно скачать МИ 1997 -89 в нормальном состоянии. Прошелся по многим электронным библиотекам, но ее или нет, а если и есть то в ужасном состоянии. Может у кого нибудь есть эта методика в электронном виде? Есть такая. Качество не ахти, но и не ужасное, вполне читаемое. Цитата
vikt0r68 0 Опубликовано 3 Ноября 2010 Жалоба Опубликовано 3 Ноября 2010 Огромная просьба, где можно скачать МИ 1997 -89 в нормальном состоянии. Прошелся по многим электронным библиотекам, но ее или нет, а если и есть то в ужасном состоянии. Может у кого нибудь есть эта методика в электронном виде? Есть такая. Качество не ахти, но и не ужасное, вполне читаемое. Если можно, то сбросте по электронке vkozlov@tbnenergo.com. Заранее благодарен. Цитата
Алал 245 Опубликовано 3 Ноября 2010 Жалоба Опубликовано 3 Ноября 2010 нужна методика поверки датчиков давления метран 150 Методику поверки нашёл, но загрузка файлов в топик СНОВА не работает. Давайте адрес. Цитата
Alekcvolkov 18 Опубликовано 19 Апреля 2011 Жалоба Опубликовано 19 Апреля 2011 Друзья, немогу найти методики поверки потенциометрических датчиков давления типа МД и 2МД (НПО "Сигнал" г.Энгельс), индуктивных датчиков давления типа ДДИ, МДДФ-УК. Номер в госреестре найти не могу (сам сайт что-то плохо работает). Может кто сталкивался с подобным вопросом? Цитата
Специалисты su215 658 Опубликовано 19 Апреля 2011 Специалисты Жалоба Опубликовано 19 Апреля 2011 Датчиков МД и 2МД производства НПО "Сигнал" в реестре нет. МДДФ-УК тоже не нашёл. ДДИ : есть ДДИ-1 (№24076-08), поверяются по МП 13-221-2002, утв. УНИИМ в 2002 г.; Корунд-ДДИ (№14446-09), МИ 1997-89; Сапфир-22МР-ДДИ (№42768-09), МП та же. Цитата
Alekcvolkov 18 Опубликовано 19 Апреля 2011 Жалоба Опубликовано 19 Апреля 2011 Датчиков МД и 2МД производства НПО "Сигнал" в реестре нет. МДДФ-УК тоже не нашёл. ДДИ : есть ДДИ-1 (№24076-08), поверяются по МП 13-221-2002, утв. УНИИМ в 2002 г.; Корунд-ДДИ (№14446-09), МИ 1997-89; Сапфир-22МР-ДДИ (№42768-09), МП та же. Игорь Юрьевич, я правильно ищу номера в госреестре Моя ссылка. А то я что-то даже ваши номера найти не могу? Цитата
Специалисты su215 658 Опубликовано 19 Апреля 2011 Специалисты Жалоба Опубликовано 19 Апреля 2011 Датчиков МД и 2МД производства НПО "Сигнал" в реестре нет. МДДФ-УК тоже не нашёл. ДДИ : есть ДДИ-1 (№24076-08), поверяются по МП 13-221-2002, утв. УНИИМ в 2002 г.; Корунд-ДДИ (№14446-09), МИ 1997-89; Сапфир-22МР-ДДИ (№42768-09), МП та же. Игорь Юрьевич, я правильно ищу номера в госреестре Моя ссылка. А то я что-то даже ваши номера найти не могу? Этот фонд ещё только заполняется. У нас подключена официальная база ГРСИ. Последнее обновление - прошлого года, в этом ещё не обновлялась. Цитата
Alekcvolkov 18 Опубликовано 19 Апреля 2011 Жалоба Опубликовано 19 Апреля 2011 Ух ты!!!! Крутотетская крутотень.... Тогда в калибровку их? Цитата
Специалисты su215 658 Опубликовано 19 Апреля 2011 Специалисты Жалоба Опубликовано 19 Апреля 2011 Скиньте информацию поподробнее, я ещё раз проверю по реестру. (До 17-00 можно сюда : ivanushkin@kcsm.ru) Если не найдутся, тогда калибровка. Привозите, сделаем. Цитата
Alekcvolkov 18 Опубликовано 19 Апреля 2011 Жалоба Опубликовано 19 Апреля 2011 Мы их сами поверяем сотнями на протяжении вот уже 40 лет. Власть поменялась, начал разбираться что к чему! Оказалась, вот такая канитель! В рестре нет, в сферу ГРОЕИ входят, методику поверки не найдешь...Щас справляемся с помощью своей-же инструкции по поверке. Спрошу у своего главного метролога....как он думает? Цитата
Специалисты su215 658 Опубликовано 19 Апреля 2011 Специалисты Жалоба Опубликовано 19 Апреля 2011 1. Поскольку меня терзали смутные сомнения, сейчас зашёл на сайт НПО "Сигнал". Вы уверены, что Ваши датчики называются МД и 2МД? 2. Датчики ДДИ, - это, скорее всего ДДИ-20 производства ЦАТИ. Они неутверждённого типа. Ещё я вспомнил, мне когда-то давно приносили на калибровку ДДИ-140, тоже неутверждённого типа. Кто производит, не помню. 3. Датчики МДДФ-УК производит ОАО "Утёс" (Ульяновск). В реестре не нашёл. Цитата
Alekcvolkov 18 Опубликовано 20 Апреля 2011 Жалоба Опубликовано 20 Апреля 2011 1. Поскольку меня терзали смутные сомнения, сейчас зашёл на сайт НПО "Сигнал". Вы уверены, что Ваши датчики называются МД и 2МД? 2. Датчики ДДИ, - это, скорее всего ДДИ-20 производства ЦАТИ. Они неутверждённого типа. Ещё я вспомнил, мне когда-то давно приносили на калибровку ДДИ-140, тоже неутверждённого типа. Кто производит, не помню. 3. Датчики МДДФ-УК производит ОАО "Утёс" (Ульяновск). В реестре не нашёл. Да точно, МД и 2 МД (сдвоенные) ООО ЭПО "Сигнал". Сам был удивлен, что их нет на сайте. Индуктивные ДДИ-20 и ДДИ-21 (с водяным охлаждением) может быть и ЦАТИ, на схеме похож. Цитата
Fralia 0 Опубликовано 4 Мая 2011 Жалоба Опубликовано 4 Мая 2011 Очень Нужна методика поверки на рН-метр иономер Итан.Пожалуйста скинте ссылку) Цитата
Akvt347 0 Опубликовано 18 Июля 2011 Жалоба Опубликовано 18 Июля 2011 Уважаемые коллеги подскажите,вот этот гос.реестр..методика поверки каждого манометра или датчика написанна там? Цитата
68 сообщений в этой теме
